Add traction control....
Re: Add traction control....
buy a 95 F-body with it, then swap everything over..........
the things that are different are:
body wiring harness
dash harness
switch in dash
both rear brake lines(non tcs has 1, tcs has 2, both are different then the non cars)
brake lines on rear axle
rear axle(non had 1 ABS sensor on top of diff, TC had 2, one inside the rotors on each side)
the EBCM/EBTCM
the ABS HCU(unit under the hood)
the throttle cables(non had 1 , tc had 2 shorter ones)
throttle unit/black thing on the drivers side valve cover
possible PCM programing
body wiring harness
dash harness
switch in dash
the EBCM/EBTCM
Originally Posted by devilisht2003
how can i add it to a 95 Z???
NewsBot
09-14-2015 09:20 AM
08-07-2015 01:26 PM
