Adjusting Fan Temp Activation on LT1 350 OBD2
Old 07-11-2023 | 09:24 AM
maralada's Avatar
Question Adjusting Fan Temp Activation on LT1 350 OBD2
Hey, Team!
I recently acquired a 1996 Z28/SS - love it. Never been happier. However, she naturally runs a little hotter than ideal. In my previous lt1 I had a switch, but this time I would like to try to adjust the temperature point that the fans turn on. Does anyone have any tips on how to adjust the fan speed through OBD2 and not OBD1. Ideally, I would love to figure out how to modify it myself so I can improve my personal skills. Thank you all!
Old 07-11-2023 | 09:39 AM
Re: Adjusting Fan Temp Activation on LT1 350 OBD2
Fan on/off temperatures are in the PCM program. You need programming software to flash the new temps into the program. Or you could have a mail order tuner make the change.
You could also find an old hand held Hypertech Power Programmer (HPP). Has the ability to alter fan on/off temperatures in the PCM. If you find an HPP, you have to make sure the previous owner reset the program in his PCM to stock, or else it won’t work on your VIN. The HPP has a few other useful features, but the “power program” is a dud.
What coolant temperatures are you seeing that you feel are “a little hotter than ideal”? The engine was designed to run at the midpoint of the dash gauge 210°F). Stock thermostat is 180°F. You could consider a 160° replacement and lower fan on/off temps. Might pick up a few HP, but will increase emissions slightly and may lose a fraction of an MPG.
Old 07-11-2023 | 10:04 AM
maralada's Avatar
Injuneer! It's great to hear from you! As of right now, the temperature idling in a hot parking lot in Nashville actually goes ever so slightly above the midpoint of the dash gauge - kinda like 215-220°Fish. But as soon as a I start moving the temperature drops to midway between the middle and bottom of the dash gauge. Water pump is not leaking - checked the weap hole too - and both fans are turning on. My fist hope is its nothing mechanical - it only has 45000 miles on it and has been intensely serviced since 1996; excellently maintained.
Okay! I see! I heard about HPP - just never knew that was an option for us.
I have an SLP 160°F thermostat ready for action and my intent was to aim for 200°F For low/210°F for High if I could figure out a way to adjust the PCM haha.
I appreciate you helping me so much!
johnrule
08-13-2005 08:06 AM
hllywd
11-19-2004 12:41 AM
Super Slow '97
08-22-2004 09:20 AM
ASIM
07-09-2004 10:53 AM
Tires_Smokin
09-23-2003 03:44 PM
Quick Reply: Adjusting Fan Temp Activation on LT1 350 OBD2
