Air pump fuse keeps blowing...
Ok, so i figured out my SES light is on because of the air pump fuse blowing. I changed it, started and it was fine for five minutes. Then it blew,the light came on along with the fans. I know there has been others with this problem. The Air pump is bad am i right? It keeps blowing the fuse when it tries to cycle on? If so where can i get a new pump? Any help would be appreciated.
The was a recall on several years of 4th gens because of this issue. Not sure the exact fix because I never took mine in (no air pumps ) but since it is emissions related you should be able to contact the dealer and ask them if your car has had (if it needs it) the recall.
I had the same problem. All you need to do is diconnect the electrical plug going into the air pump. Problem solved. Of course the pump wont work, but it's not really needed anyway. You can see the pump from the drivers side. Just reach down and un-clip the connector.
Originally posted by Injuneer
Recall was only for 95 and newer. Did not cover 94's.
Thanks for keeping me honest, Fred!
stockssn2o
05-25-2015 08:54 AM
Magenta_Hearts
03-05-2015 07:01 AM
