AutoMeter Triple Pod A Pillar
I am hoping this is the correct forum for this question. I am wanting to install a full A-pillar triple gauge pod set up on my 1994 Formula. I would also like to use AutoMeter, but am open for some other brand suggestions.
Now I was told that all the A-pillars for 93-02 T-Top Cars are basically the same, the only difference is the little circular vent being on the later models. They (Summit) only lists them for 1997-2002 T-Top Cars. PN# ATM-12213. Will these fit on my 94 Formula with T Tops? Do you have any other suggestions? Also I am looking to get a Tranny Temp Gauge for sure, a Nitrous Gauge, and I want a Fuel Pressure gauge but they have to be mounted outside the car. Do you have a suggestion for the third?
Thanks for your assistance.
You simply buy an electronic fuel pressure gauge, and it can be mounted inside the car, because nothing but the wires enters the passenger compartment. I have the three center vents filled with an electronic fuel pressure gauge, mechanical nitrous gauge and mechanical oil pressure gauge. Electronic oil temp and tranny temp in a 2-pod pillar molded to the stock A-pillar cover. Click on "step into my office....." below.
[edit]
The online AutoMeter catalog shows that the 3-gauge pod part # 12213 fits the 93-02 Firebirds and the 97-02 Camaros. Its the Camaros that have the extra defroster hole starting in 97.
Eastwood Company "graphite" vinyl paint will match your interior, ifs its the same color as mine.
[edit]
08-05-2015 08:35 AM
