Bad BCM??????
Old 11-13-2004 | 03:42 PM
Red97LT1's Avatar
Question Bad BCM??????
My interior lights will some times pop on when i open the passenger side door and some times it won't. It will sometimes chime when i try to lock the door and the passenger side door is open. The drivers side works fine. i have replaced the door switch and the switch is getting power.Could the bcm be bad???
Old 11-13-2004 | 04:20 PM
Red97LT1's Avatar
Re: Bad BCM??????
Well,i wnet back out to try some other things and now everything is working fine. I didn't do anything,so i don't know what happen.I'm leaving along unless it does it again.
Old 11-13-2004 | 04:47 PM
Kataklysm's Avatar
Re: Bad BCM??????
Weird things like that happen alot. My keyless entry randomly stops working for a few hours then it's fine. If it with lights you should check wiring, could be a bad connection.
Old 11-13-2004 | 09:17 PM
Re: Bad BCM??????
The door jamb switches working by completing the connection of the circuit to ground. Perhaps you have an intermittent or weak ground on that door jamb.
Old 11-13-2004 | 10:42 PM
Re: Bad BCM??????
Perhaps it might help if you looked for troubles codes from the BCM.
OutlawPerforman
10-30-2017 05:40 PM
Jocofire1
08-07-2015 03:16 PM
zajones
07-30-2015 02:18 PM
colts0455
07-08-2015 12:21 AM
colts0455
07-07-2015 07:19 PM
Quick Reply: Bad BCM??????
