bad posi/ which tire spins more
Old 10-02-2004 | 03:02 PM
CamaroSS30thAnn's Avatar
which tire will spin more when ur posi unit is bad
my right tire will lose traction on a right hand turn more than my left will on a left hand turn....i do know i need a gear oil change, will that help me out ?
Old 10-03-2004 | 04:04 AM
BiGGinZ's Avatar
Re: bad posi/ which tire spins more
If something is going wrong you would just need to get a new limited slip.
Old 10-03-2004 | 03:35 PM
iNF3RNo's Avatar
Do a small burnout, if you see one tread mark, then your posi is bad.
The gear oil change won't do anything for a broken posi, but it will help stop from a broken read end.
Old 10-03-2004 | 06:35 PM
i can do a burnout and both tire will spin and leave a mark....if i make a right hand turn my pasenger tire will spin more, if i make a left the driver wont spin as much as the right would in teh opposite case
i hope u get what i mean ...
Old 10-03-2004 | 09:54 PM
unvc92camarors's Avatar
sounds like your posi is working backwards
your inner tire is always spinning less as the outer tire has more ground to travel=spin more, etc.
can't help ya but it does sound like something is wrong
just make it a drag only car and you shouldnt have a problem though
Old 10-03-2004 | 10:44 PM
I don't think you have much of (if any) problem. Why do you even care if it leaves even black marks going around a corner? The inside tire is always going to lose traction first, because the posi is trying to make it spin as fast as the outside tire. That's what you feel when turning a sharp corner under a little power.
Old 10-04-2004 | 09:57 AM
good point
how much does the stock posi give power to one wheel?
i thought the zexel could do 100% to one wheel right? (which is on the 96-97 ss's as an option and standard on some ls1s iirc)
i'm just wondering what the stock one can balance out at like 80%/20% or whatever
just curious
Old 10-04-2004 | 11:46 AM
Z28SORR's Avatar
This is almost impossible to quantify on the street or track, unless you go to a skid pad with instrumentation and run in both directions.
The 80/20%, is good for most types of posi's.
Old 10-04-2004 | 01:10 PM
yea, i wasn't looking for exact, just something that they might have advertised
i was leaning toward it being 80/20 though, thanks for the answer
CGM2010CAMARO
04-07-2015 07:44 PM
AlaskaZ28
12-16-2014 07:24 PM
AlaskaZ28
12-10-2014 02:39 PM
AlaskaZ28
12-10-2014 02:37 PM
Quick Reply: bad posi/ which tire spins more
