bad seat foam
Old 09-25-2019 | 08:41 PM
scottpdx2010's Avatar
bad seat foam
hi there, I am looking for any help or advice. I have a 1996 Formulia Firebird. as with many of these F-bodies the seat foam is loosing its mass. the seat now leans me into the door. the foam is warn down or lost its push on the drivers side in the base or seat pad, and the back where you get in and out of the car. GM no longer makes a replacement and the only company I ever found OER model #SF240 they quit selling. so like so many people I can only imagine are looking for this, so am I. if you guys know anyone making the foam pad that would fit a 1993-1997 (maybe up to 2002 but not sure) F-body, I would love to know where. or if you have a different solution you could give, that would realy be appreciated.
thanks in advance for your help
Old 09-25-2019 | 08:53 PM
Re: bad seat foam
Did you follow up on the suggestion you received a few weeks ago?
https://www.camaroz28.com/forums/gen...m-help-887689/
Old 09-25-2019 | 09:06 PM
Re: bad seat foam
I am going to use that as a fall back, but I would realy like it replace it if possible. I did find a guy that said he could do it, I just would like new if at all possible. not to sure how good patching the foam will work. have you done it or known someone that did? if so, wow well did it hold up after it was done??
Old 09-26-2019 | 08:29 AM
1994-LT1-Eric's Avatar
Re: bad seat foam
I've got original cloth interior on my Z28 and have decided to have both front and back seats reupholstered, and to install new carpet with dynamat under it. Trying to get out really old stains and patch a couple holes probably isn't gonna fly.
Just depends on what you wanna reach in your pocket for. An upholstery shop would give you your best recommendation. Keep in mind they wanna make money. A detail shop can tell you if your upholstery is worth salvaging.
scottpdx2010
08-17-2019 08:03 PM
PipesTA
West North Central
01-07-2005 10:22 PM
Need4Camaro
V6 Tech
07-28-2004 09:12 PM
StngStlkr
04-01-2004 09:50 PM
SpeC
04-01-2004 10:36 AM
Quick Reply: bad seat foam
