Battery Questions: Deep Cycle?
Old 05-19-2005 | 01:29 AM
BBB's Avatar
BBB
Ok, I invested in a Dynabatt battery (dry cell, very small and light) and I was wondering:
1. What is a deep cycle battery? What does that mean?
2. Should/can I charge my dynabatt on a deep cycle setting or normal trickle charge?
BBB
Old 05-21-2005 | 01:16 PM
BBB's Avatar
BBB
Re: Battery Questions: Deep Cycle?
Did I stump the whole crowd?
BBB
Old 05-21-2005 | 03:07 PM
MasterEvilAce's Avatar
Deep cycle batteries can be drained/recharged drastically and will last a whole lot longer under those situations.. for example if you play music and have powerful sub woofers with the car off, the battery will drain a good bit over time, you won't have to worry too much about the battery not holding a charge when you go to recharge it
if you've got time, you should always trickle charge, the battery will last longer and hold a charge better
Old 05-22-2005 | 11:20 PM
BBB's Avatar
BBB
BBB
Old 05-23-2005 | 07:00 AM
Rashiki's Avatar
AGM (absorbed glass mat) batteries can also be mounted upside down and sideways, and never need filling with fluid They offer more consistient performance, and also, as said above, be drained and recharged more times than other batteries, and stand up better to abuse.
Optima red top here
Old 05-23-2005 | 07:04 AM
Now I have a question about those.. do those have problems with sulfuric acid or hydrogen, or any of that leaking out of the case? As in if you had one would the acid rust/eat away the battery holder?
blac94Z
11-04-2015 01:59 PM
PopoFormula
10-12-2015 04:19 PM
68camaroboltz
10-05-2015 01:46 PM
95craz28
11
09-12-2015 07:47 AM
jackpawt883
09-10-2015 08:53 PM
Quick Reply: Battery Questions: Deep Cycle?
