Blinkers stopped working today
I was on my way to work and tried to use my blinkers and the damn dash light would just stay lit up and wouldn't blink. It does that for both sides. When I got to work I checked to see if the actual blinkers were working, nada, they just stay lit up also.
What are some quick checks I can do while I am at work?
Re: Blinkers stopped working today
Originally Posted by Bayer-Z28
Try your four ways. If they dont work, it's probably the relay. Check fuses and bulbs. The relay should be in under where your fuses are. It's a round type relay.
When one does it, its the bulb, because they are dual element bulbs and the four ways can work while the turn signal won't. If they both do it at the same time, it'd be what you found, the flasher.
