Brake lights Tail lights out, third brake light works Question
Old 10-11-2005 | 08:51 AM
gixxer92's Avatar
Anyone know why the Third brake light would work when I step on the brakes and the regular tail light brake lights don't?
I have turn signals and emergency flashers working?????
The stock replacement bulbs, are two element bulbs aren't they? I mean they were working a couple of weeks ago. I have to believe the element isn't burned out if I get turn signals and emergency flashers.
Old 10-11-2005 | 02:04 PM
Z28SORR's Avatar
Re: Brake lights Tail lights out, third brake light works Question
Remember the third brake light harness is seperate from the rest of the tail lights. The 4th Gen. rear light sockets are notorious for corrosion. I would start there and then check the harness.
Old 10-11-2005 | 03:13 PM
camaros4ever's Avatar
It is a blown fuse, I have seen this on a ton of cars, thats all it should be
Old 10-11-2005 | 06:00 PM
gixxer92's Avatar
I looked at the fuses on the side panel inside the door, the one that said Brakes/flashers. Better go ohm it out.
AlaskaZ28
01-01-2015 12:30 PM
Red97LT1
9
12-17-2014 06:13 PM
fpete1992
12-11-2014 03:51 PM
siguy
11-27-2014 10:07 AM
07-04-2005 05:00 PM
Quick Reply: Brake lights Tail lights out, third brake light works Question
