Broke trany mount
Old 06-14-2014 | 01:51 AM
MakinAMeanZ28's Avatar
Broke trany mount
Broke trany mount twice. Shifts hard out of 1st and 2nd. Can the hard shift break trany mount? And what causes hard shift? Also what are good mods starting off. Not a daily driver. Gunna be a work in progress. Going to do most of work myself. It's a 94 z28.
Old 06-14-2014 | 06:59 AM
Re: Broke trany mount
Broken trans mount is a common problem. Every time you accelerate, the torque arm pulls up on the front torque arm mount, which is attached to the tailshaft of the transmission. That will tear a rotted rubber trans mount, which in your case could be 20 years old. Hard shifts simply increase the impact on the torque arm.
Hard shifts can be caused by a "shift kit" installed in the transmission, or altered PCM tables that control the 4L60E shifting. Do you know the history of the car/transmission?
G-BODYT56
01-14-2022 11:14 PM
truecontr3
10-11-2015 09:30 AM
alliance12364
09-23-2015 12:40 PM
alliance12364
09-23-2015 06:09 AM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: Broke trany mount
