broken drivers side window frame
Old 04-24-2014 | 12:45 AM
Brandon Wittmer's Avatar
When I bought my car I noticed the window would slide back and forth I took off the door panel off and the wheel that goes up and down in the verticle track is broke off and gone looks as off I have to pull the window out of the door I tried to get It out but don't seem to fit any suggestions on how to get it out
Old 04-24-2014 | 10:02 AM
Re: broken drivers side window frame
Probably help if you provided info on the year of the car.
Why not add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. That gives people the info they need to help you.
Old 04-24-2014 | 10:36 PM
My bad it's a 94 z28
Old 04-25-2014 | 05:54 AM
4th Gen 4 Life's Avatar
In order to get the window out you have to take the whole crank assembly out and then the clips off of window. This may be common because before I fixed all my windows I noticed my vertical roller had been welded in place. I have a extra window I would be willing to sell fairly cheap. Not sure if that bracket comes off or not. I will check later. If so I could just sell the bracket.
Sent from my Z796C using Tapatalk
Old 04-25-2014 | 08:59 AM
Well Its all pop riveted together so was hoping it came out as one piece so I didn't have to mess with trin g to put it back together I was gonna drill and tap the old wheel and bolt it back on but I had it in my cup holder and my wife decided to clean my car out
Keenan
01-19-2023 12:24 PM
mattstrike
03-11-2015 07:33 PM
The Seer
11-20-2014 06:32 AM
07-04-2005 05:00 PM
x7x7
08-15-2002 06:49 PM
Quick Reply: broken drivers side window frame
