A/C and Heater Problem?
Old 03-12-2005 | 02:53 PM
NOS2006's Avatar
Well going down the road the other day I noticed my feet getting hot, but my body not. So I check the heater and it's off, so I put my window down for a few. Put the window back up and a little later my feet are hot again. I put my hand down there and I feel heat coming from the vent. Strangely though, I turn the Cold/Hot nozzle on the heater panel to cold and it blows out cool air...
Can I get a possible explanation, please?
Old 03-12-2005 | 09:43 PM
Re: A/C and Heater Problem?
Hard to guess without some info about the year of the car, but if its a 4th Gen the flapper doors that switch between heat/cold, and AC/heater are vacuum controlled. Either you've lost the vacuum to the flapper doors, or the actuator on the door is bad. Then again, if its a 1st Gen, it might be slipping actuator cables......
Old 03-12-2005 | 10:21 PM
There is always some air that flows through, even when the blower is off (when the car is in forward motion). If the temp **** is on the hot side, then it will be hot air. If you switch the **** to cool, then it will be cool.
Old 03-12-2005 | 10:30 PM
JJayzX's Avatar
When you drive the air is forced thru basically it.
Old 03-13-2005 | 07:46 PM
NOS2006's Avatar
I didn't know there was still air that flowed through...
BTW, I have a 1998 w/ the 3.8
kksi
02-17-2015 10:41 PM
01-23-2015 01:13 PM
alphaauto
01-23-2015 07:42 AM
Britbilly
01-07-2015 08:49 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: A/C and Heater Problem?
