A/C not working, any thoughts?
I know I probably just need to take it into an A/C shop, but before I do I just thought I throw it out here for any possible easy fixes.
My 95Z has the 134a system. I can't seem to get the clutch to engage. I put freon into it, and is all up to pressure. Still nothing. I then notice someone had the compressor unplugged, so I fished around the engine bay and found it and got it hooked up again. Still nothing. I was told it could possibly be one of my switches, either the high or low pressure switch. Anyone ran into this before? Also I'm not throwing any SES codes for A/C. I'm open to any thoughts. Thanks all!
Re: A/C not working, any thoughts?
Thanks, for the suggestion, sorry I forgot to mention the check the fuses and the relay. I switched 2 relays around and still didn't get anything. I assume the relays are all the same, I may be waaaaay off on that one though.
Try to pull the PCM BAT fuse for about 30 secs. On my 94 it is on the end of the dash drivers side. This will clear the code in the computer indicating the system is too low on pressure. Assuming your R134 is full enough and no other issues this will allow the compressor to kick on.
Thats what I was thinking, but if it's low on freon it won't engage either, and somehow it pulls enough freon in to the system start engaging when you fill it up(not mine though )
If the system is low on freon then no, the clutch will not engage. You can get the clutch to engage by bypassing the refrigerant pressure sensor.
http://shbox.com/1/refrigerant_sensor.jpg
10-31-2016 11:09 AM
