a/c question ?
a/c question ?
hi everybody i installed a new ac compressor and for some reason there's little air coming out it's cold and sometimes there's no air coming out and i know the compressor is on and i could hear the blower running but no air through the vent ?
pcv check valve in new so any ideas on the solution ??
Re: a/c question ?
i installed a new ac compressor and charged it up was working for a few minutes then all of a sudden there's no air coming out of the vents but the ac compressor was working and i could also hear the blower but the air was not coming out at all, i could have it on full blast and compared to my mustang it's like if it was in low when the a/c is working it's on and off it's like if the air going somewhere else or something.
another thing i should thow in i have never had a/c since i've been the owner of the car (4 years).
Re: a/c question ?
i took a look it a little closer and air is going to the bottom so i'm looking for a vacum leak right? i took a good look under the dash and seen a part that kind of looks like A fuel pressure regulator it say's delco remy! and has a 1/8 to 1/4 size nipple like if there's suppose to be a hose there but there ain't ?
this is on a 94 z28
this is on a 94 z28
Re: a/c question ?
this is on a 94 z28
this is on a 94 z28
Re: a/c question ?
that regulator looking thing you see is a vacuum controled door actuator. find the vacuum hose that fell off it and you should be set.
on another note why did you need a new compressor?
Re: a/c question ?
yup it was off it was the purple hose now i;m going to take it for a test drive but on idle it seem's so far to be throwin more air .
thanks allot guy's i take it for a run in a few minutes
old compressor was making a nasty noise the clutch went south because of a short.
jasonduaine
03-07-2015 09:44 AM
