Can a Canadian find a low cost fuel pump
Mine has not gone out yet but I have over 110K (miles) so soon I expect issues. I already have a spare opti/water pump (still on originals too) on the shelf and would like to put a new fuel pump on the shelf as well.
Where are Canadians getting their fuel pumps from?? And how much $$ ??
I got the racetronix pump from the link below was around $300 CDN shipped
http://www.thunderracing.com/catalog...vid=4&pcid=166
You bought the whole kit I assume.
If you buy just the pump does it install without modification, is it an easy install?
Im in the neighborhood for a clutch right now, but everwhere is too exp. man i wished i lived in the states. I always wondered what it would be like to go somewhere and not have to pay an arm and a leg for something so common, or going to a part-store and them ACTUALLY having something in stock for our cars.What a world that would be
end rant * sorry for not having anything to do with topic *
I didn't get the harness kit just the pump. The install is not bad just follow the directions they give you. Gotta decide whether to drop the rear end and tank or cut an acess hole in the trunk.
Contact Eric at Victory Racing there service is awesome
For the pump install, you dont need to drop the tank.
Follow this link:
http://www.geocities.com/formulapower2/fuelpump.html
Easy and really clean
Follow this link:
Follow this link:
Mine is a keeper as I won't be able to afford anything else as my three kids are all teenagers and college/university is expensive so I am trying to keep it unmolested as possible. Up here a 93 that has never seen salt, and with the mph for speedo and the pearl purple is not all that common.
$300CAN shipped for a $160US pump, was that back when the Canadian dollar was worthless???
I am going to drop the tank in mine as well as it will give me a chance to clean it out, check under the body up above the tank. In another 15 years one of the things that will be good is that I didn't cut a trap door. The guys that don't pan to keep them for ever well it probably doesn't matter. As you have said yes to each his own.
In the link,i didnt like the way that he finished is trap(metal screw and scealler) so i begin to think on the how to improve the design...
I inspired myself from my last car(92 awd talon).From factory there was a trap in the trunk to reach the fuel pump assy(really bright idea from the injuneer).
I cut mine and use small hinges on one side and a lock on the other so it look like a small door.I put some rubber insulation all around the trap and it look like really clean and could nt tell if it was there from the power plant.Also just before mounting everything i apply some zcoat of zinc primer,primer and paint so it would be clean and rust free.
Thats the way i see it but at the end your the owner of the car and you do want you want
