Can a Canadian find a low cost fuel pump
Old 11-04-2006, 05:17 PM
  #16
FastZinTennessee's Avatar
Originally Posted by always faster
You can do it right with this method
If the GM engineers wanted you accessing the fuel pump in the way you are describing, they would have put an access panel there for you.
The right way of doing something never requires you to do something irreversible to your car, like cutting a huge F'ing hole in the sheetmetal.
But hey, if you want to cut a hole in your car right above the gas tank and fuel lines, then put the door on a hinge, be my guest :blah:
FastZinTennessee is offline
10-31-2016 11:09 AM
RiverMutant96
01-30-2015 09:21 AM
Jessie4tin
01-07-2015 08:53 AM
ANDYZ28
12-29-2014 09:13 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
Quick Reply: Can a Canadian find a low cost fuel pump
