Convertable leak(pump fluid)
Old 03-12-2005 | 06:18 AM
tc3's Avatar
tc3
when i got the car the top pump wouldnt budge the convertable top, look and saw it was out of fluid, so obviosly it was leaking. Later on i discovered that the drivers side back seat was soakin up all the convertable pump fluid.
so right now i have the back seats on my bed(stinkin up my room) so i can access the shock where it is probobly leaking. Took the side plastic off and the speaker. I could(barley) see that their was some junk on the top of the shock where the shaft comes out the top and maybe some on the top connector.
Sorry if im making this seem more complicated than it is but the question is, HOW IN THE HELL AM I SUPPOST TO WORK ON THIS THING?????
the crap around it is welded together so i cant remove that...
Does anyone have any experience in this, can you help me out with trying to find/fix this leak?
How much does a new shock cost if that is the problem?
Sorry for making it so long, but any help would be apprieciated...
(this is the second time posting this, but when i put in appearance forum it was said that i should put it here, and it got no responses there, so here it is...)
Old 03-14-2005 | 08:22 AM
tc3's Avatar
tc3
Re: Convertable leak(pump fluid)
ok well then could someone tell me how to refill the fluid and what fluid to use? maybe that is a question that someone will know???
Magenta_Hearts
03-29-2017 08:54 PM
PCLZ28
12-24-2015 05:19 PM
WildRidez
02-23-2015 07:24 PM
alex5366
02-17-2015 10:43 PM
Nostang 96z
09-10-2002 08:54 PM
Quick Reply: Convertable leak(pump fluid)
