Could having an upgraded intake allow the engine to run cooler?
Old 11-14-2011 | 02:08 PM
97z28k&N's Avatar
Lightbulb Could having an upgraded intake allow the engine to run cooler?
I am just wondering if there is any chance that an upgraded intake could slightly lower the engines operating temperature.
Old 11-14-2011 | 03:13 PM
n2ceptor's Avatar
Re: Could having an upgraded intake allow the engine to run cooler?
Like an AirGap intake would allow for cooler air, but should not effect operating temp...
Old 11-14-2011 | 06:57 PM
rv93's Avatar
no, it wouldnt. letting more cold air into the engine might make some of the parts like the intake manifold run a *bit* cooler, but only at wot when youre letting all that air in, and the extra power youre making would probably heat it back up to where it was before or higher anyway
Old 11-14-2011 | 08:09 PM
one bad Z28's Avatar
A throttle body bypass can lower intake temperature on the LT1 engine.
Scottylt1
01-08-2015 02:48 PM
Jazsun
12-29-2014 12:14 PM
Scottylt1
12-04-2014 12:31 PM
Vokabulis
07-25-2002 05:46 AM
Quick Reply: Could having an upgraded intake allow the engine to run cooler?
