Creaking in rear
Old 02-22-2005 | 05:06 PM
mergleh00SS's Avatar
Creaking in rear
Hey guys,
I recently noticed there was a creaking in the rear (dunno how long its been goin on, because you can only hear it when the window is down on the drivers side, and its been a bit cold around here). It only occurs between 10 and 35mph, the faster you go the faster the creaks are. I can tap the gas and hear it real well, if i apply the brake a bit, like slowing down gradually, i can still hear it, but if i hit the brake a bit hard, it goes away. Any ideas what the problem is?
Thanks,
Scott
Old 02-22-2005 | 08:17 PM
RE AND CHERYL's Avatar
Re: Creaking in rear
First on my list would be a bad belt in a tire. Rotate the tires and see if it moves.
Old 02-23-2005 | 12:27 AM
ok, ill try that this weekend, ty for reply
Old 02-23-2005 | 04:00 AM
PJS TOY's Avatar
Before you go to all the trouble of switching the tires, try just pushing the rear end down with your body weight. If it creaks, go no further, grease the sway bar bushings under the axle. If not, the tires are next.
PJ
Old 02-23-2005 | 07:46 AM
96ss2nv's Avatar
Also grease the lower control arm/panhard rod bushings. Mine are squeaking like crazy right now. If these parts are stock on your car, you'll have to take one bolt out at a time and swing the arm down to get to the bushings. Aftermarket arms have zerk fittings, you can just use a grease gun with them.
Old 02-23-2005 | 10:09 AM
sounds good! thanks!
96SilverRam
11-20-2016 11:19 AM
HarleyZ28
10-05-2015 06:23 AM
BLK1997Z28
05-01-2015 12:23 PM
BPS
9
03-05-2015 10:51 PM
Quick Reply: Creaking in rear
