Dash lights indicate I am low on everything...huh?
My low oil light keeps coming on. Next time I start the vehicle it is off and the low coolant light comes on after a little driving. If neither of these is lit up then my Service engine soon light comes on. Sometimes things are normal and there are no warning lights. I have checked all the fluids and they are at capacity. What the heck is going on?
Re: Dash lights indicate I am low on everything...huh?
You car is possesed by demons!!!
About the only thing I could think of is there might be a loose connection but it would need to be one that is common to all 3 lights?????
low coolant sensor is broken, normal for a 1995 f-body. find the radiator cap and look down below it on the engine side of the radiator (not the front) ... there is a grey box on the radiator with some wires comming out of it. disconnect that. no more low coolant light.
as long as you've checked the oil level and your absolutly sure its fine, then the sensor is bad... happens. not sure if unplugging it will fix that.
as for the SES light, time to get the car scanned and see what code is popping up.
Magenta_Hearts
03-29-2017 08:54 PM
01-23-2015 01:13 PM
fpete1992
12-11-2014 03:51 PM
