dashboard crack
Old 06-30-2005 | 01:12 PM
Jeremy1's Avatar
Unhappy dashboard crack
The wide, flat, horizontal, plastic panel above my dashboard is cracked. I have no idea why, noticed it last night. Only thing I can think of is that it cracked from the heat. Has anyone else had this problem and needed to replace it before?
Am looking for where to buy (the name of this piece would be helpful) and if anyone has had any experience replacing. Seems like quite a job, especially since I will be messing around behind the passenger side airbag.
My car is a '95 BTW. 93-96 interior should be the same.
Old 06-30-2005 | 01:22 PM
sabre81's Avatar
Re: dashboard crack
Is it the dash pad that your talking about? This thing ?
http://i.b5z.net/i/u/509876/i/camaro...a_dash_pad.jpg
Old 06-30-2005 | 02:18 PM
Jeremy1's Avatar
Re: dashboard crack
yes exactly. That is called the dash pad?
I assume to get it off I have to remove the a-pillar covers but I am not really sure.
Old 06-30-2005 | 03:26 PM
Z06Z28's Avatar
Re: dashboard crack
Mine just cracked the other day, I'm not happy about this.
It's about $100 bucks I think. It's part #10267171 (dash panel) 93-96, double check by calling Dal or Jason on the wholesale dealer page at shbox.com.
Old 07-01-2005 | 12:05 PM
Jeremy1's Avatar
Re: dashboard crack
its lists at $169 from a dealer but you can get for $96 from gm parts direct. I'm going to check the junkyard too.
Has anyone changed this before? Do you have to actually take the front of the dash apart, or can you get at it from the top by removing the A-pillar covers? I'm guessing there are plastic clips holding it on, but I really have no idea.
It would be great if you can change it without removing the dash.
Old 07-01-2005 | 12:54 PM
Dave89IROC's Avatar
Re: dashboard crack
pop off the a pillar pieces, and pop off the pad, its all just clips
Old 07-01-2005 | 12:55 PM
breakmyfootoff's Avatar
Re: dashboard crack
All you have to do is remobe the a pillars and the gently pull it up, it's held in place with several spots of super strength industrial Binford 2100 velcro.
Old 07-01-2005 | 03:20 PM
Jeremy1's Avatar
Re: dashboard crack
glad to hear that. thanks
Old 07-01-2005 | 03:26 PM
Donohue96M6Z28's Avatar
Re: dashboard crack
ya mine just cracked yesterday its really thin tho ,barely noticeable but i know its gonna get bigger , anyway to stop it from getting bigger u think?
magman
04-15-2016 03:08 AM
David Dempsey
03-12-2016 12:42 AM
Daluchman1974
09-11-2015 06:12 AM
scottcba1
09-08-2015 09:52 AM
alphaauto
07-26-2015 04:40 PM
Quick Reply: dashboard crack
