Defogger Switch
Defogger Switch
Has anyone deleted their rear defogger and used the switch for something else like to turn on/off fans, line-lock, or nitrous?
Don't have my rear defogger anymore and would like to use that button for something.
Re: Defogger Switch
Not sure for certain but the rear defogger switch might be a specialized switch as it automatically turns off the defogger after 15 minutes. Not sure if the switch performs the timing or the Body Control Module.
Re: Defogger Switch
I used the small 12 volt hot wire and the light to install my trans temp guage.
you can use the hole with another switch but if I remember correctly there is a little circuit board in the switch to turn it off after a set time.
Delete your foglights and use that as your fan switch. I was thinkin of doing this with my tranny cooler fan.
jackpawt883
09-10-2015 08:53 PM
