Dex-a-cool or regular?
#17
Re: Dex-a-cool or regular?
how can you see the "muddy coolant??"
whenever i have drained the radiator it comes out pretty clean and the "filler tube with dipstick" always comes out clean.
is the mud in the heater core or does it stay in the system ???
eh, sucks to get this kinda news
#18
#19
You've been changing it every year AND using distilled water so you are already doing what you need to do to keep Dexcool from mudding up your cooling system. I wouldn't worry about switching as long as you keep up on the maintenance.
#20
I've seen some adverse reactions of the dexcool with aluminum. I'm not sure if it was directly involved, but a engine running green and an engine running orange, i've always had more corrosion with the orange.
IMHO, NO coolant should be in there very long no matter what the f'ing color. Just like 100k mile spark plugs...yeah right...
-Shannon
-Shannon
#21
-Shannon
-Shannon
#22
while i can't speak for you guys, as i mentioned before my uncle works on chevy trucks for maintenance
he says everytime he pulls parts out, they're as clean as they were when they were put in (with dexcool on a 5 year or 100k interval)
not sure if the radiators are aluminum or something else, but he says it works well in what he sees
he uses it in his cars too, so just something to throw into the mix
#23
Here's some more info: http://www.imcool.com/articles/antif...l-macs2001.htm
#24
#25
Originally Posted by spawnz28
Very informative link ty! I recently swapped out my water pump on my 02' z28 and drained the radiator, I refilled it with what came in my car, which was dex-cool. I did notice that the over fill tank did have some orange crud on the "dipstick" of the overfill cap. I heard that depending on what type of radiator you have, depends on what type of radiator fluid you should use. How true is that? should a stock radiator from 02' z28 be using only dex-cool, like it came from the factory? Can I switch to the "green stuff" and what do you guys think the advantages or disadvantages would be? After reading that article I am tempted to purchase that video but am unsure of what I should do. I think if I maintain my radiator fluid levels like I should everything will be ok.
that's my rule of thumb
they put what works in from the factory
just keep up on maintenance and check it periodically
#27
Originally Posted by blind527
how many bottles of dex cool will i need to fill my radiator and the recovery tank??? i have completely out of coolant.
EDIT: I would also purchase a measurement funnel, they sell them just for this purpose. It will allow you to make sure you have all/most of the air our of the system, they're only a couple of dollars.
cmsmith
09-14-2015 09:25 PM
