Do I have 3 channel or 4 channel ABS?
Car is a 97 Trans Am with traction control. Were all cars with trac control 4 channel?
I briefly was under the car, and saw a weather pack connection on each end of the axle, so I'm guessing 4 channel, right?
I'm looking at upgrading to a stronger rear and needed to know. Thanks.
Re: Do I have 3 channel or 4 channel ABS?
I suspect you are correct, but to tell for sure just look at your ABS pump. If it has 3 lines exiting it, you have 3 channel. If it has 4 lines exiting it, you have 4 channel.
Henson071
09-21-2015 04:31 PM
