Driver seat foward & rear tilt not working
Old 03-15-2007 | 01:09 PM
TheV6Bird's Avatar
Has anyone ever had this?
I'm driving a 97 Camaro convertible right now with 4 way manual seats (forward, backward, tilt front of seat up, tilt front of seat down) and it only moves backwards and fowards....the ability to tilt the seat isn't working.
I've tried to look underneath the seat, and it looks like the tilt lever is connected to a small metal wire (think throttle body linkage type wire) that is then connected to something on the left side of bottom of the seat (closest to the driver side door). Other than that, I am stumped.
Anyone ever try to fix the tilt of their seat?
Old 03-15-2007 | 01:12 PM
2000GTP's Avatar
It could just be a bad switch, not uncommon at all.
Old 03-15-2007 | 03:41 PM
Lunch Box's Avatar
The original poster said manual adjustable seats . . . so probably not the switch
Old 03-15-2007 | 04:08 PM
TheV6Bird's Avatar
Yeah they are manual seats, but I took the entire driver's seat out of the car (sure is easy to do that with a convertible with the top down), and the manual lever itself seems to be working fine...I have a feeling that the sliding units themselves are just stuck and hopefully some WD-40 will cure that.
Old 03-15-2007 | 04:45 PM
TheV6Bird's Avatar
OMFG this thing is a trip: took the seat bracket out to get a better look around and I just can't figure out what is up with these things! I even have the GM shop manual for 1997 F-bodies and even that doesn't go into any detail whatsoever about the tilt mechanism,
Old 03-15-2007 | 07:12 PM
TheV6Bird's Avatar
I give up...I bolted the bracket into the car without the seat attached, and then tried lifting the lever and pulling as hard as I could but no luck. If this car wasn't trying to be sold, I'd go junkyard hunting.
Collector Car
01-05-2015 10:58 AM
siguy
11-27-2014 10:07 AM
BIGCOWL-IMP
11-21-2014 09:40 AM
Snoman73
11-17-2014 07:22 PM
BOOGER
07-25-2002 02:42 PM
Quick Reply: Driver seat foward & rear tilt not working
