Easiest way to drain fuel? 93 Z28
Old 01-18-2011 | 07:33 PM
Chadh's Avatar
Anyone have any ideas on what the easiest way to drain out some rotten fuel from a 93 Z28? Is there a drain plug on the gas tank? I thought about unhooking a fuel line from somewhere and turning the key on and let the fuel pump do all the work for me but I'm not sure of the best place to unhook a fuel line from where I can actually drain the fuel into a can and not all over the car/engine. Any ideas would be greatly appreciated. Thanks!
Old 01-18-2011 | 07:51 PM
RamAir95TA's Avatar
Re: Easiest way to drain fuel? 93 Z28
If the fuel is "rotten" I'd cut the hole in the hatch, pop off the cover and siphon it out using a drill pump. Using the factory pump on old fuel can accelerate failure. You can try it if you want. There is a fuel pump prime connector in the engine bay where you can apply 12v+ and run the pump.
Then again I'd probably replace it anyway, so use option #1.
Old 01-18-2011 | 10:48 PM
If you want to disconnect a fuel line, do it at the fuel filter, not in the engine compartment.
I've had good luck siphoning the fuel out of the tank.] via the fill neck.
Old 01-20-2011 | 10:25 AM
Z28SORR's Avatar
What's "rotten" about the fuel?
Old 01-20-2011 | 01:35 PM
Chadh's Avatar
It's about 6 years old.. as in it's bad gas and smells "rotten".
Garcia5
07-07-2022 06:51 PM
10-31-2016 11:09 AM
artic94
01-17-2015 11:19 AM
Sandersen511
01-13-2015 03:49 PM
07-04-2005 05:00 PM
Quick Reply: Easiest way to drain fuel? 93 Z28
