Electric rear window de-fog problem
For the last couple of weeks my rear window de-fog has only been staying on 3-4 mins instead of the 10 mins it used to stay on,then it shuts off & won't work again for about 10 mins.I believe the circuit breaker is tripping that controls the de-fog/pwr seats because for those 10 mins the seats won't function either.
My question is...What are the chances that the circuit breaker is wearing out compared to the possibility of a bigger problem ?(such as a short,etc)
Has anyone else had this problem ? It's on my '99 Z/28 with 65,000 mi if that helps.Thanks
Yep I replaced mine and now it works great. If I remember right its the big silver looking metal fuze. I replaced mine with a 30 amp twice now... problem is is that they get hot and melt but they dont actually blow. Not sure why this is happening.
Sorry,thought you were interchanging the terms circuit breaker & fuse to mean the same thing,but........
Do you have any idea what would be causing the problem ? There must be an underlying issue that would cause the circuit breaker to trip,right ?
It happens to most everyone. Over time and for whatever reason (maybe just age), resistance in the circuit increases to more than what the breaker can hold. The fuse gets hot, but will hold most times and still give you protection of 30A on the circuit. Keep a couple of extras in the glovebox for emergencies.
A fuse and a circuit breaker are not the same and I would never interchange the terms.
Is there any chance that there might be dirt/dust build-up on the contact points that could be causing the added resistance ?
My '84 doesn't have that problem at all,it's never blown a fuse for the rear de-fog. Is that set-up different ?
