EVAP Solenoid Lines
Old 02-24-2012 | 07:50 AM
Mystic_350's Avatar
EVAP Solenoid Lines
I'm putting my motor back together and can't remember a few specifics.
On the passenger side "fuel rail" area, there is an EVAP solenoid between cylinders 4 and 6. A few inches in front of that, there is a secondary solenoid with two ports. One port (top port) goes to a hard plastic line that is bundled with the fuel lines over on the drivers side, does anyone know where the 2nd (bottom) port goes? I don't have any left over lines, and no idea where that is supposed to connect to either.
http://www.autoblog.com/media/2006/03/EFI-6.JPG
Thanks in advance,
Chris
Old 02-24-2012 | 11:43 AM
Re: EVAP Solenoid Lines
One is the solenoid, the other is the vacuum detection switch (what you are calling the secondary solenoid) that was added with OBD-II. Shoebox has a diagram:
http://shbox.com/1/1996_evap.jpg
The vacuum detection switch has a vent hose that doesn't connect to anything.
Make sure you get the correct line on the correct solenoid connection, or you will end up with code P1441.
Old 02-24-2012 | 11:19 PM
Mystic_350's Avatar
Thanks Fred,
I can't find/didn't find that link off of Shoebox's site, I've been using it extensively as I go, and the only related link I could find was this one: http://shbox.com/1/evap_sol.jpg
Regardless, thanks again! I was meticulous about bagging/labelling everything that came off the motor, so much so that I was very surprised that I couldn't find any hose to hook up to that lower vent hose. Guess it makes sense now though as there is no hose to hook up!
Chris
HectorM52
07-30-2017 11:46 AM
Strick
05-26-2015 11:41 AM
Jazsun
12-29-2014 12:14 PM
blac94Z
11-28-2014 01:53 PM
Quick Reply: EVAP Solenoid Lines
