Fuel Pump Failure?
Re: Fuel Pump Failure?
It more likely it would run worse in open loop with a failing fuel pump, since in open loop the PCM can not use the short term fuel corrections to compensate for low fuel flow. It would run better in closed loop, because now the PCM would be able to use the ST's to compensate.
Its not likely that its the fuel pump, but why guess. Put a fuel pressure gauge on it and verify it is performing correctly.
A gauge was put on, but it was said that
"Just because it's giving ideal pressure, doesn't mean it's giving ideal volume"
I take it, this statement is false?
The Mechanic claims it's fuel related because once he sprays gas down one of the intake lines, the car runs great with no popping or signs of running lean (at idle).
Sounds like my car is doing the exact same thing in those conditions, interesting...I'll keep following this thread. Keep us updated so I can try a few things out.
Also...
I have Autotap scanning software for Palm just lying in my garage, anyone familiar with using it? Haven't really used it much.
Also...
If the system can't supply enough fuel, the pressure in the system will drop.
The only way the above statement could be true is if you only measured the system pressure at idle, and not at full load. Then, the system may run out of fuel when the engine is under load. But that would mean the fuel pressure was not measured correctly.
I have a new fuel pump going in today/tomorrow so we'll find out then.
He said the car ran perfect when he sprayed Starter Fluid/Gas into the intake or vacuum line... I forgot. haha So we're trying the fuel pump/fuel regulator first.
Originally Posted by MarcR94v6
What is open and closed loop?
Check out the air/fuel management section of this writeup:
http://members.aol.com/InjuneerZZ/ScanMast.htm
10-31-2016 11:09 AM
