fuel pump fuse question
Re: fuel pump fuse question
Shoebox has the wiring diagrams for a 1995 Z28 on his website, along with a ton of other useful info. If you haven't found that site yet, you need to go there.
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_wiring
That shows that the fuel pump relay is supplied +12V power by Fuse #5 in the dash panel fuse box. That fuse also supplies the PCM and the MAF sensor.
10-31-2016 11:09 AM
