Got code P0102 on my v6
Low MAF signal. Hooked up my shops snapon scanner and the MAF is reading 0 for every input. Pretty much the MAF is not working, but the car still drives, the idle is kinda jumpy also.
Anyone know the resistance, voltage, etc for the MAF.
It's a 2000 v6 auto
It's a 2000 v6 auto
Check to make sure the MAF sensor is getting +12V power. There should be a pink wire in the connector that supplies the 12V power to the sensor. If you have 12V and a good ground, its probably a faulty sensor.
The output signal from the MAF sensor is a variable AC frequency. The PCM has a table that converts the frequency to mass-air flow in grams/second. The code sets when the frequency drops below 1200HZ.
johnsocal
08-29-2002 10:01 AM
Darth Xed
14
08-07-2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
07-08-2002 01:37 AM
