Heater Core
Heater Core
I have a stock 94 Camaro Z-28. Occasionally as I'm driving along, I will smell antifreeze inside of the car and then the smell will go away. The windshield fogs up a little, but not all the time. The car is not leaking antifreeze on the ground and I didn't see antifreeze anywhere under the hood. Should I change the heater core or are there any hoses that I need to check for pin holes or anything. Thanks!
It's heater core time!
I just changed out the heater core in my '94 Z-28 after the windshield fogged. No mist coming out of the vents (not that I saw anyway), and not much smell, but definitely coolant fog.
The heater core swap isn't too bad, about 3 hours work, taking your time. Others have posted a DIY guide here, do a search and you'll find it.
HTH, and have a good one,
Mike
Mike
ducttape1975
07-10-2015 06:29 PM
