help with brakes
Old 09-25-2008 | 07:53 PM
96camaroz281988's Avatar
help with brakes
okay i was driving the car home i heard a noise and it sounded like i ran over a pop can or a rock hit the window but the noise came from the rear i got have way home and i noticed the ASR light was on so i go to push the button to turn it off but it was not working bu the brake were working fine. so i started the car up this morning to move the car and my foot went to the floor on the brake and the low traction light came on. when i apply light pressure to the brake pedal it is firm but when i go to to apply more pressure to stop the car the pedal goes to the floor. any one have a clue whats going on.
Old 09-25-2008 | 10:32 PM
Is the "BRAKE" light on?
Old 09-26-2008 | 05:03 AM
nope
Old 09-26-2008 | 07:00 AM
Get under it and scope out all the brake lines and look for any fluid leakage.
Old 09-26-2008 | 07:30 AM
NukeFPE's Avatar
X2
Did you check the level in the Master Cylinder?
Old 09-26-2008 | 01:29 PM
master cylinder is full, no brake lines are leaking. i think it is the booster because it only happens when the car is at a crawl. because when you apply the brake at like 15 mph you have good brake pressure then when you get to like 5 mph all brake pressure is gone and the car just about does not want to stop.
edit: I just got done bleeding the system and that did not work i noticed that when the pedal loses pressure and gets almost to a complete stop the drive side front tire locks up. it is acting like something in the system is getting confused and spazing out.
magman
04-15-2016 03:08 AM
IndyZman
10-22-2015 02:17 PM
Matt Dreessen
09-09-2015 09:58 PM
cohopefull
09-08-2015 03:22 PM
maverickmk
09-01-2015 09:17 PM
Quick Reply: help with brakes
