help! its getting cold and i need my heat to work!
My heater blow all cold. No hot. Here in Missouri its getting cold so i need this resolved ASAP!. When I turn the dial to warm it dosnt blow as hard. And the defroat does not blow jot either. What is the correct way to bleed the system? Also could it be a clogged hose? Please help.
Thanks In advanced. NintythreeZ28
Re: help! its getting cold and i need my heat to work!
Flush the heater core and bleed the system usually works. Here's a "how-to" link....
http://shbox.com/1/4th_gen_tech2.html#heaterflush
They probably are suggesting that you back flush the heater core. If you are lucky that will fix it. If not then you will need a new heater core. See this link for the heater hose routing.
http://shbox.com/1/heater_hoses_93-94.jpg
remember to backflush the system...water goes IN the OUT...
Backflush worked great. Heat is blasting. Thanks for the help. If anyone reading this is going to do it in the near future be very careful with the opti. Wrap it up or something. I got a little on it and it ran like poo for a minute. Sputtered and died a time or too. Dried out now its running like a champ again. Thanks for he help
01-23-2015 01:13 PM
