help with sputtering ... details inside
Old 03-14-2005 | 04:14 PM
snake_skinner93's Avatar
'93 Z28. ok ... i have the air temperature sensor removed and i think that is my main problem with the sputtering, but its only just now beginning. my Trans-Am air temperature sensor was messed up, and since i never drive my '93 i swapped the '93 sensor into the TA. so, thats the reason for not having a sensor in the '93. so, after the car is at normal operating temps, it sputters through all gears. like its not getting any air. i have a high idle (around 1700-2000rpms) and was told by a good friend/mechanic that my vacuum hoses may need replacing since i've already replaced the IAC sensor. so could the vacuum hoses have a hand in the sputtering as well? Its not an Opti promblem, already changed that and the sputtering never occured until i removed the sensor. i may be answering my own question here, but i was just curious if anyone else has had a smiliar problem?
08-22-2015 01:09 AM
truthmatters
3rd Gen / L98 Engine Tech
08-19-2015 04:09 PM
techstar
08-06-2015 11:20 AM
BMX Dad
08-03-2015 09:15 AM
BMX Dad
07-27-2015 02:39 PM
Quick Reply: help with sputtering ... details inside
