honestly.... how do i jack up the front of the car
Old 09-19-2005 | 10:00 PM
colossus's Avatar
i can not seem to find a place to put a floor jack on the front of the car (94 formula). I know there are places on both sides of the car for the "jack stands" but they're just like little blocks of plastic and i dont know if i wanna trust them. So where do all of you guys put your floor jack to get the front up???
Old 09-19-2005 | 10:03 PM
JAG05's Avatar
Re: honestly.... how do i jack up the front of the car
I usually jack on that side piece get one side up, put a jack stand under it than since one side of the front is up its easy to get a jack under there and jack both sides up.
Old 09-19-2005 | 10:05 PM
Jameslt1TA's Avatar
I put the jack under the k-member. But my jack is fairly long.
Old 09-19-2005 | 10:16 PM
1racerdude's Avatar
Under "A" frames.
Old 09-19-2005 | 10:19 PM
hallbilly's Avatar
lol... being the hick that i am... to take all trouble and complexity out of this. use two boards... put them infront of your tires... pull up on them.. 2x4's work but wider is better. dont need to be too long... be careful in grass cause the boards will pop up and hit your fenders if they are too long
Old 09-19-2005 | 10:57 PM
CamaroSS30thAnn's Avatar
i made ramps out of 2 boards on each side and pulled up on them then jacked on the K member
Old 09-19-2005 | 11:10 PM
cammed_aro Z28's Avatar
i put the jack under the k member and jack the whole thing up at once, then i put the jack stands where the a frame pivots from. the smaller jackstands have about the same curvature as that point. holds good enough for me. i am not scared to start jerking on stuff under the car.
Old 09-20-2005 | 06:56 AM
moparman's Avatar
The pads, on each side, behind the fenderwells, are the correct jacking points.
Old 09-20-2005 | 07:32 AM
2000GTP's Avatar
I do either the k-member or the plastic blocks on the sides, depends on what I need to do.
Old 09-20-2005 | 11:01 AM
CatsTasteGood's Avatar
Those plastic pads are NOT the jacking point...it even says it right there on the car "do not jack here". They are attached to the plastic fenders and you will cause them to bow out. If the car is running, use ramps, if not...either push the front wheels onto some boards or jack up each side enough to get boards under each wheel. Then use a block of wood and jack up the kmember. I like to put my jack stands behind where the kmember bolts to the body...its about where the front of the door is.
Old 09-20-2005 | 11:32 AM
moparman's Avatar
The pads are the jacking point. That's why they're there. The warning refers to the fender lip, not the pads.
Old 09-20-2005 | 11:46 AM
1-bad-z28's Avatar
the pads are for a lift only....not a jack. If you put a flat piece of wood on top of your jack, you can jack there.
Old 09-20-2005 | 11:52 AM
moparman's Avatar
No, they are for a jack. GM doesn't give you a piece of wood to go with the jack in the hatch, do they?
Old 09-20-2005 | 12:03 PM
anaik's Avatar
A floor jack that has a cup to contact the plastic, is better served with a piece of wood to even out pressure. The jack that comes with the car is a sissors which has a flat surface to lift with.
Edit; I looked in my owners manual, and the jack that comes with the car has a raised portion that fits into a notch behind the front wheel and in front of the rear wheel. My mistake.
Old 09-20-2005 | 07:46 PM
colossus's Avatar
sooo.... is it decided that you can jack on the plastic pads if you place a piece of wood between the jack and the pads??
Quick Reply: honestly.... how do i jack up the front of the car
