How can you adjust the position of the steering wheel?
Old 07-28-2004 | 01:07 PM
KeVMaN's Avatar
My steering wheel used to sit perfectly straight, but someone tried to steal my car a few weeks ago, and i ended up having to replace the steering column. now, my wheel is like an 8th of a turn to the right. Is there any way to adjust this? the wheel only goes on one way
Old 07-28-2004 | 01:39 PM
TraceZ's Avatar
Re: How can you adjust the position of the steering wheel?
You can center it using the tie rod ends. Make sure you count the turns and turn both sides the same amount so you dont screw up the allignment.
I wonder why it is off?
Old 07-28-2004 | 04:52 PM
KeVMaN's Avatar
I don't know i'm assuming the column is twisted or something. Doesn't really matter... I duno, i ended up modifying the steering wheel so it's adjustable... so problem solved until i get a new column and do it right.
Fastbird93
04-09-2016 07:01 PM
Airplanedoc
02-01-2015 07:14 PM
ro2207
12-04-2014 06:18 PM
07-04-2005 05:00 PM
SLIMJIM
01-07-2003 11:06 AM
Quick Reply: How can you adjust the position of the steering wheel?
