How do I get the seat belt guide off the belt? ---
Old 02-08-2008 | 07:27 AM
AlwaysCode390's Avatar
Question How do I get the seat belt guide off the belt? ---
I have a broken seat belt guide , and want to replace it. Do I have to take apart the floor mount, slide off the belt clip, then the guide?
What are the steps I should take? Its super cold out... and I dont want to trouble shoot out there, hahaha. Thanks for the help ---
Old 02-08-2008 | 02:38 PM
WestCoast96Z28's Avatar
I haven't done this, but looking at it, it looks like you remove the floor mount. But I don't think you need to remove the clip. I "think" the clip will slide past the seat belt guide (attached to seat) if turned the right way.
Old 02-08-2008 | 09:03 PM
GreasyB's Avatar
Mine is broken too. The only problem I see about taking the floor mount is that once you get that off. I do not think the buckle part will just slid off in order for the guide to come off.
Old 02-09-2008 | 12:55 AM
acre's Avatar
Its been about 5 years since I did this, so my memory is a little foggy. You have to unbolt the seatbelt from the floor, and I'm pretty sure the buckle fit through the seat belt guide, so you can just slide the broken guide off and slide the new one up from the bottom past the buckle. It was pretty easy when I did it.
Old 02-10-2008 | 10:24 AM
I think the guide will go past the buckle if you wrestle a bit ... I tried a quick second before I drove off to work , and it didnt just "slide through" ... thanks guys for the help so far ---
Old 02-11-2008 | 01:32 AM
GreasyB's Avatar
So did you end up getting it fixed and how?
Formula Steve
09-19-2023 08:31 AM
rideordie
09-07-2015 08:22 AM
Conteur1234
08-29-2015 10:52 AM
WPHIG2
08-27-2015 06:37 AM
07-17-2015 02:47 PM
Quick Reply: How do I get the seat belt guide off the belt? ---
