How do you check transmission fluid?
Old 03-21-2008 | 03:37 PM
IRONFIST's Avatar
Well, anyone want to let me know? I've never checked transmission fluid in a T56, and can't find any way to do it? I want to make sure the level is ok, because the transmission "grinds" when cold.
Old 03-21-2008 | 05:02 PM
LSWHO's Avatar
Warm up the car. Park on even ground. Pull the dipstick and wipe it off. Put it back in wait a bit and pull it back out and read it.
Old 03-21-2008 | 05:07 PM
Interceptor1's Avatar
But the T56 is a manual transmission, does it have a dipstick? I've never seen a manual tranny with one...?
Old 03-21-2008 | 05:28 PM
ImportedRoomate's Avatar
I know on some transmissions you have to remove a plug and check to see the level is up near the hole.
Old 03-21-2008 | 06:24 PM
moparman's Avatar
Remove the filler plug, stick a finger in the hole and see how close to the hole it is.
Old 03-22-2008 | 01:13 AM
IRONFIST's Avatar
But how full should it be?
Yah there is no dip stick. I just can't find any other reason to explain why the transmission grinds when cold, but runs just fine when up to operating temp.
Old 03-22-2008 | 06:52 AM
Chevycobb's Avatar
it should be just to the bottom of the hole. just be sure to pull the FILL plug and NOTthe DRAIN plug
it can be a bitch to get off, so get ready to be pissed off at it
Old 03-22-2008 | 07:55 AM
Old 03-22-2008 | 03:16 PM
IRONFIST's Avatar
Ahh, that really helps, thanks guys. I'll get back here after I'm done...
Old 03-22-2008 | 04:18 PM
Z28SORR's Avatar
P.S. Remember the T56 takes ATF.
Old 03-22-2008 | 04:29 PM
Chevycobb's Avatar
yes, Dex III ATF if it seems you are low, or if you just want to change it.
if you are going to add or change...its a PITA to pour it in that fill plug so leave the fill plug off with something underneath the trans to catch any fluid. Lower car and remove shifter then pour it into there instead. MUCH easier IMO, then when it starts to come out the fill hole you know you have enough
Old 03-22-2008 | 06:35 PM
moparman's Avatar
Put a hose on a funnel. Stick the hose in the filler hole and you can pour it in from the top.
Old 03-19-2009 | 04:57 PM
350350's Avatar
So how many quarts of DexIII should I buy to do a full change?
And do I need to recheck/refill after driving the first time after the change?
I have mine out on the garage floor right now so it's easy to do before I shove the whole shootin' match back in there.
Old 03-19-2009 | 06:34 PM
moparman's Avatar
It holds eight pints.
Old 03-19-2009 | 06:39 PM
350350's Avatar
LOL, amazing exactly the amount of liquor *I* can hold!!!
Although they don't call them 'pints' in the US yet do they?
captcorvette
03-07-2015 12:37 PM
jmadoll
03-03-2015 10:16 AM
teal98
15
09-16-2002 01:23 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
Quick Reply: How do you check transmission fluid?
