How do you remove the airbag "cover"?
Old 05-06-2014 | 03:36 PM
Orangejews's Avatar
I need to gain access to the horn switch assembly for repair/replacement but can't figure out how to remove the cover on the front of the steering wheel. I tried lightly prying at it but don't want to damage anything and certainly don't want the airbag to deploy. Any tips on getting in there?
1995 Z28
T56 Trans
ACT 6 puck Clutch/FW/PP
Comp Cam
Custom 3" mandrel Exhaust
DC High-Flow Cat
HAWKS short shifter
Old 05-06-2014 | 03:41 PM
4th Gen 4 Life's Avatar
Re: How do you remove the airbag "cover"?
If you feel behind the steering wheel there should be two bolts/screws holding it in place. Be sure to pull the airbag fuse just to be safe and not trigger it off.
Sent from my Z796C using Tapatalk
Old 05-06-2014 | 04:04 PM
GaryDoug's Avatar
Prominent Member
I believe there are four #30 TORX screws holding the driver side inflater module. I recommend disconecting the battery and waiting 20 minutes before working, just to be safe. Once the inflater is removed, you can connect the battery again if necessary. When placing the inflater module on a bench or shelf, leave the front facing up with nothing on top of it.
greenzee28
09-25-2015 04:29 PM
Jake Bialke
09-24-2015 11:31 AM
wbspoon
09-19-2015 08:12 AM
NewsBot
09-14-2015 09:20 AM
RX Speed Works
09-11-2015 03:31 PM
Quick Reply: How do you remove the airbag "cover"?
