How do you remove the Cooling Fans???
Old 06-28-2006 | 07:44 PM
BadgeZ28's Avatar
I need to swap fans on a LS1 F-Body for a supercharger install. How do you remove the whole cooling fan assembly? I know I need to unplug the electrical connections, and remove the air cleaner shroud. Does the cooling system need draining for hose removal? Does the assembly come out the top or bottom? Thanks.
Old 06-28-2006 | 09:33 PM
Re: How do you remove the Cooling Fans???
Unplug the fans and lift the fan assy off it's mounting hooks. I wrangled mine out the bottom. Hoses will give some interference.
grabbem88
04-16-2015 06:57 PM
Magenta_Hearts
03-25-2015 10:24 AM
MattFick
02-15-2015 10:16 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
IrocSS85
07-18-2002 10:35 PM
Quick Reply: How do you remove the Cooling Fans???
