How is your power steering?????
Old 09-29-2004 | 06:11 AM
  #16
Birdman7389's Avatar
Re: How is your power steering?????
Originally Posted by Jeffs94Z28
I think im going to bend the header in a little more.
just pull off your steering shaft, and bend/pund in the two little tabs that stick up off the rag joint. Thats where it hits right?
Old 09-29-2004 | 09:50 AM
  #17
slayer6x6's Avatar
Originally Posted by tomatocity
it should not be noisy enough to be noticable.
Oh really :blah:
Old 09-29-2004 | 09:59 AM
  #18
91 Camaro RS's Avatar
My power steering works like a dream, nice and tight. Gotta have nice tight steering in a sports car.
Old 09-29-2004 | 03:36 PM
  #19
Blue96z28's Avatar
are there any spots related to the steering that could/should/need to be lubricated?
Old 09-29-2004 | 05:14 PM
  #20
slayer6x6's Avatar
Im pretty sure the lower ball joints are the only components with grease fittings on them. Unless you have aftermarket parts.
Old 09-29-2004 | 10:36 PM
  #21
Originally Posted by tavella
My power steering has gotten looser and looser. Often if I hit a groove in the road, my car will follow it. It hasn't been the same since I had the tires changed and the guy from "Wrong Turn" who was I'd say 300lbs+ drove it in and out of the shop.... I was told by GM that my high pressure hose was leaking but my fluid level hasn't changed in the past 8 mo since I was told that... I'm lost.
if you have changed your tire size to any wider than previously, the car will have more of a tendency to find grooves in the road, and will pull toward the direction of the "crown" of the road
Old 10-01-2004 | 11:01 AM
  #22
Patrick96Z28's Avatar
Yeah, I've got 315 on the front, 245 on the back and I'm all over the place!
Old 10-01-2004 | 03:21 PM
  #23
bond449798's Avatar
Originally Posted by 97WS6SCharged
My power steering is tight and easy to operate. I've never had any problems from it. As far as idle speed goes, my 6 speed car has always idled around 900-1000 RPM.
that sounds kind of high but maybe not i have an auto and my car idle's at
500rpm
Old 10-01-2004 | 04:20 PM
  #24
500rpm
Mine also idles at 1000rpm.
Old 10-01-2004 | 04:54 PM
  #25
rokudan's Avatar
Mine is similiar.. I notice when I back up and turn the wheel, the car is just idling, it has a bit of a "Rough Spot" Also when turning into my driveway which is inclined and I am driving slow, it again exhibits the rouch spot.
Drove my dads Caddy the other day and it made it seem like I dont even have power steering... But from every muscle car I've ever owned I have seen the same... Power steering usually takes a back seat to other performance enhancements..
Oh yeah, I idle at about 700 regardless of whether or not the AC is on.. On cold start generally around 900-1000..
mspennyhughes
03-01-2015 03:50 PM
Quick Reply: How is your power steering?????
