hub question
hub question
ok took the pulley of then took the center bolt out of the middle of the hub now how the hell do i take the hub out..?? its a 94 lt1
Re: hub question
Sadly, I can't help with your question, but you have posted the same question into multiple forums more than a few times. You may wish to delete one thread or the other since that's considered an abuse and/or rude around this forum.
Heck you've even been warned before.
Good luck with your trouble!
Re: hub question
Get a 3 bolt pulley puller and a longer version of the middle bolt that you took out of the hub. Then thread that longer bolt in the middle a little, then use the pulley puller from there.
Re: hub question
Ignoring the mods advice is a VERY GOOD way to get yourself banned. You've been warned, yet continue the same crap cluttering up multiple forums. This is an LT1 issue, so post it there and NOWHERE else. Make sense?
That being said, you need a hub puller, go rent/buy one.
Re: hub question
"What we have here is a failure to communicate."
I've asked you just recently not to scattergun the same problem on multiple forums. The people above have also given you some good advice. PLEASE listen.
Locking.... again.
Locking.... again.
stockssn2o
05-25-2015 08:54 AM
mschmidt33
03-15-2015 07:20 PM
cyteone
02-07-2015 06:04 PM
