I have some technical questions
Old 02-18-2005 | 02:55 PM
EIPITL's Avatar
Post I have some technical questions
Hi Guys
I am new to this cool forum and I loved the style of it ..
I am newbie to cars and I have a questions I hope
I can find answers ..
What is the mean of bolt on ?
what are the functions of torque Converter clutch ?
is the NOS Oxide System danger to use ?
My regards !
Old 02-18-2005 | 04:01 PM
WestCoast96Z28's Avatar
Re: I have some technical questions
First of all...welcome.
Bolt-ons are modifications where it's as simple as remove old part and replace with new part, without having to do extravagent rebuilds. You can say "external" modifications: catbacks, headers, intake. Others like cam swap, changing displacement.. I wouldn't consider bolt ons.
So torque converter clutch...hmm.. automatics have torque converters in place of a clutch to disengage the engine and transmission. So, no such thing as torque converter clutch. Here's a good site to explain how TCs work:
http://auto.howstuffworks.com/torque-converter.htm
Is NOS dangerous to use...loaded question...anything can be dangerous depending on the driver. You've been watching 2 Fast 2 Furious too many times. In general, there are established NOS kits in the market that are commonly used, so under proper application, it's not dangerous.
Old 02-18-2005 | 04:19 PM
Z28Nut's Avatar
Pretty much what he said but newer automatic transmissions have lock-up torque converters that use a clutch to engage the torque converter into a 'direct drive' like manual trannys to help improve gas mileage at cruising speeds.
Old 02-18-2005 | 07:24 PM
EIPITL's Avatar
Post Re: I have some technical questions
WestCoast96Z28
Thanks Mate for your worthy reply !
I've heard that the NOS Oxide System is not dangerous at all ..
I heard that the NOS used on hospitals !
Yea I've watched Fast and furious 1 and 2 .. I saw the Eclipse in the first part ..
What gonna happen if i press NOS Button while I am not pressing at Gas Pedal ?
Z28Nut
Thanks Bro for your reply .. I've heard about that !
Old 02-18-2005 | 08:45 PM
LT4orbust's Avatar
Originally Posted by EIPITL
WestCoast96Z28
Z28Nut
the solenoids are wired to a switch on the throttle body that only allows it to come on at wot,wide open throttle.
Old 02-19-2005 | 05:58 AM
EIPITL's Avatar
Is this only in the camaro or all cars ?
How much NOS OXIDE system can the Stock LS1 handle ? 70shot ?
Old 02-19-2005 | 04:39 PM
LT4orbust's Avatar
it is how you should do it on just about any car, the kits are wired this way.
i've heard of the ls1's running around 150 to 175 hp shot stock, do a seach on the n20 section below the lt1 tech section, also you should use what is called a window switch, it allows the n20 to start and stop at set rpm's.
don't hit the n20 below 3000 rpm unless you have a bit of experience with it, 3000 is a safe point to bring it in under wot.
Old 02-19-2005 | 05:11 PM
EIPITL's Avatar
thanks man
I am wondering what will happen if you press the nos from idling (( low rpm )) ? I guess it's will be hard to control ??
Old 02-19-2005 | 05:59 PM
LT4orbust's Avatar
from an idle, probably break a piston or rod maybe a crank, i don't know of anybody trying that, do not do that.
read up on n20 , there is plenty of info on this web site, like i said , go to the n20 section and just start reading. lots of good info and a little bad, good luck, ps ....nitrous is very fun to use
Old 02-20-2005 | 10:29 PM
Z28Nut's Avatar
EIPITL -- Along with LT4orbust's excellent suggestion of reading the N2O section of this board, the latest issue of Chevy High Performance magazine has a very good article on nitrous.
N2O is used in hospitals and dentists. Every time I go to the dentist, I try to talk him out of a bottle of N2O but he thinks I'm just trying to get a buzz, lol. I tell him the buzz I'd get running it in the car at the strip would be much bigger The cute little blond dental assistant always asks how the car is running
jasonduaine
03-07-2015 09:44 AM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Hurin
12-13-2014 07:38 PM
Brian Demeter
04-05-2004 05:18 PM
Quick Reply: I have some technical questions
