I just replaced the intake gaskets and now the radiator fans won’t kick on.
This weekend I replaced the intake gaskets following shoeboxes cam removal guide. It started up great, but the radiator fans won’t kick on and the temp is steadily rising.
I replaced the coolant that was drained, would burping possibly solve this issue, or is there something I could have forgotten?
Re: I just replaced the intake gaskets and now the radiator fans won’t kick on.
Most likely the gauge sensor, located toward the rear in the driver side head was in an air bubble, and was heating up due to no coolant. The gauge indicated heating up.
But the PCM coolant temp sensor in the water pump base was fully submerged in circulating cooling, and told the PCM the coolant was below the fan turn on temp (226°F), so the fan(s) didn't turn on.
it was low enough for the thermostat hose to be mostly empty. I gave it a few squeezes and burped quite a bit of air out of the bleeders. And it worked right away.
