I pipe question
Old 02-22-2005 | 12:50 PM
JDW18's Avatar
I pipe question
i have a 97 firebird with the LT-1 i have mac short headers and a 3 inch y pipe and also a flowmaster muffler but i have the stock I pipe and the only thing i can find to buy one by itself is from summit but its for an ls-1 would it work it looks identical ? or would i have to go get one custom made the I pipe from summit comes in 2 peices and together its only like 95$ its made by dynomax
Old 02-22-2005 | 03:41 PM
Kataklysm's Avatar
Re: I pipe question
Buy a whole new cat back...If you upgrade to a bigger I pipe only your over the axle pipe is still 2.5 inches and is going to stop the performance you would gain from the I pipe. If all you have is a flowmaster muffler it isn't doing anything for performance so just put a whole new system on.
Old 02-22-2005 | 04:25 PM
teke184's Avatar
Re: I pipe question
i think he means from the Ypipe collector all the way back to the muffler inlet. since he mentioned it was 2 pieces.
i'm trying to remember how different the LS1 setup is from the dual cat setup on your 97. i don't think it's much...wouuld probably work.
call up dynomax...or call summit, they may have them but not list them.
i also know you can get the pipe from mac
JDW18's Avatar
Re: I pipe question
im saying i can buy the I pipe and the overaxle for 95$ but its for a LS-1 i was asking if it was the same and would work for my LT-1 car?
Old 02-22-2005 | 06:01 PM
Kataklysm's Avatar
Re: I pipe question
It's gonna be to short. The y pipe is different.
Old 02-22-2005 | 07:15 PM
codyss's Avatar
Re: I pipe question
Go to the Dynomax web site and look under GM Products. It will give you a PDF format list/diagram of all there F-Body exhaust stuff. Get the part numbers for the I-pipe there.
Old 02-22-2005 | 07:16 PM
JDW18's Avatar
Re: I pipe question
maybe get an adapter made? is the overaxle still the same length? could i use that and get a custom I pipe made?
Old 02-22-2005 | 10:44 PM
teke184's Avatar
Re: I pipe question
the over-axle part will be identical.
if you were to attach it to a muffler...run it over the axle and towards the front of the car...the LS1 pipe would end short of the LT1 ypipe. a simple piece of pipe would sufice for the "adapter"
Old 02-23-2005 | 12:28 AM
JDW18's Avatar
Re: I pipe question
so i would need a peice of pipe to go over a 3 in od pipe so it would be like 3 1/4 id pipe i think but other then that it would work? what about the hanger on the overaxle would i need anything special to make it work?
Old 02-23-2005 | 12:51 AM
PJS TOY's Avatar
Re: I pipe question
I had a 97 Z28 before this car. I reused the GMMG from the 97 on the 02 with no adapter. It bolted right up to the stock Y-pipe. I had to have a hanger made for the driver side tail pipe because the hanger is different for LT1 and LS1 cars. The I pipe became the same length in LT1 cars as LS1 cars in whatever year it was that they got dual cats.
PJ
Old 02-23-2005 | 12:59 AM
JDW18's Avatar
Re: I pipe question
alright cool well my muffler is already on i just dont have a 3 inch pipe between that and the y pipe so im looking at getting one summit has both peices the overaxle and I pipe total it will be 110 shipped for them both instead of 200 muffler man wanted to make me the same **** except they would make it one peice instead of two but i guess two peices is a easier install
Old 02-23-2005 | 01:11 AM
n2oblkz
Guest
Posts: n/a
Re: I pipe question
It will work. The 1996 and up I pipe and over the axle pipes should all be the same.
Old 02-23-2005 | 06:27 AM
teke184's Avatar
Re: I pipe question
i knew it was close...
all i know is the 93-95 single cat pipe will be WAY off...they needed a big S bend to get up to the ypipe.
linz
3rd Gen / L98 Engine Tech
10-22-2015 07:59 AM
onefastgta
03-19-2015 10:10 AM
MadMav
02-06-2015 11:02 PM
alphaauto
Parts Wanted
01-23-2015 06:17 PM
thenewkid
11-18-2014 12:57 PM
Quick Reply: I pipe question
