Ignition switch???
Ignition switch???
Hey everybody I went to go start my camaro it's a 94 lt1 m6 and has the common mods to it, the key lock cylinder felt like it broke and there's no resistance on my key to like start it it just turns like it's loose it won't start. I changed the key lock cylinder and it's doing the same exact same thing as my old key long cylinder. I'm not getting any lights on my dash either. My buzzer beeps on key lock cylinder, radio n headlights do come on, and battery is fully charged.
I did research and came across it can be a bad ignition switch. Any help or information I'd appreciate it guys. 😁👍🏼
Re: Ignition switch???
When you replaced the key cylinder, did you connect and adjust the rod that runs down the column to the ignition switch? The free movement/ lack of resistance could suggest that is the problem.
Or could be the ignition switch is worn and heat damaged:
4th Gen F-body Ignition Switch Replacement
I already got the steering column down and I'm going to check the ignition switch after work.
Hey Fred I apologize for the late update and to the others, my car starts up again and is running like a champ. That thin rod that connects to the ignition switch and the other end to the steering wheel column came loose. I reattached it and now we have resistance to the key lock cylinder.
I'm glad I changed the key lock cylinder because on my old one my security light would alwayes stay on and there were times when I went to go start it the light will just stay on the dash and it wouldn't start and I would have to wait until the light came off to start it.
With the new one no more security light on the dashboard.
tiafn2
12-30-2006 05:57 PM
