Ignition wire
Old 04-14-2008 | 04:48 PM
mdacton's Avatar
Ignition wire
What wire is for the ignition to cut on the PCM?
I have removed the PCM and have a stand alone....I want to wire the stand alone to the key....but need to find what wire stays hot while cranking. I checked the 3 plugs ont the pass. side kick panel on shbox and didn't find one.....Am I missing something?
It a 97 camaro
Old 04-14-2008 | 05:04 PM
It should be C220, cavity E, pink wire. That is the PCM IGN circuit. It is hot in RUN, BULB TEST and START.
I think that is the one you are looking for.
Old 04-14-2008 | 05:05 PM
mdacton's Avatar
o.k. I need to check it again.....thanks
10-31-2016 11:09 AM
ad356
04-22-2015 08:35 PM
eanhl2004
04-04-2015 12:01 PM
Ari G
12-11-2014 03:21 PM
lbrowne
11-13-2011 04:25 PM
Quick Reply: Ignition wire
