I'm having a problem gettin oil for my 91 350 tpi
Old 02-06-2011 | 03:56 AM
Liltaz1225's Avatar
Hello, I just have finished rebuilding my 91 camaro. I have installed a lt4 hotcam ls7 lifters and 1.6 roller rockers. I tried to prime my oil pump for about 10 minutes. 2 rockers got oil real good, but the rest either got none or very little. I have 60 psi so I'm gettin preassure. I tried primin with a drill. Any idea what is going on? Perhaps I Need new push rods? Thanks to anyone that can help.
Old 02-06-2011 | 07:22 AM
BC2002SS's Avatar
Re: I'm having a problem gettin oil for my 91 350 tpi
You need to rotate the engine while you prelube. when you see oil rotate 90 degrees
Old 02-06-2011 | 10:42 AM
Liltaz1225's Avatar
Thanks. Il try it when I get back. I have had ppl tell me to fire it up just put oil on the rockers myself and it should straighten itself out. I let my lifters soak but i don't think they have soak up oil yet. Do you kno if my stock pushrods would work?
linz
3rd Gen / L98 Engine Tech
10-22-2015 07:59 AM
A's 91 Z28
01-11-2015 10:58 AM
4586
12-31-2014 02:21 PM
4586
12-06-2014 05:20 PM
Lederman1976
11-30-2014 05:21 AM
Quick Reply: I'm having a problem gettin oil for my 91 350 tpi
